cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Charging Sony Wh-1000xm2
SOLUCIONADO
profile.country.PT.title
OrbitalBloo
Novo
So a couple days ago I bought the new Sony wh-1000xm2 and I was wondering if it would be a problem to charge them with a phone charger that has fast charging, because the manual only mentions the charging through the PC.
Hope someone can clarify my doubt.
1 SOLUÇÃO ACEITE
Soluções aceites
huconce
Hi @OrbitalBloo
There is no problem charing the 1000X with the phone charger,
usb only gives 5v anyway, fast charge only gives you more amps.
But it might not be compatible with fast charge...
Ver solução na publicação original
1 RESPOSTA 1
huconce
Hi @OrbitalBloo
