Hi @Monark, welcome to our forum!
I'm sorry to hear about your phone.
Does this always occur when you have the phone in your pocket and it's placed vertically? Does it switch off if you have it in your pocket horizontally or vertically on a table?
First of all, I'd recommend that you reboot your phone in safe mode, just to make sure that a third party application that you have downloaded isn't the cause of these restarts, they will be disabled while the phone is rebooted in safe mode.
If there is no change in safe mode, try removing the SIM and/or SD cards from your phone.
Let me know how it goes!
Hi @Mido0071, welcome to our forum!
I'm sorry to hear that you are experiencing the same behaviour with your phone.
If there was no change while the phone was rebooted in safe mode and both SIM and SD cards weren't mounted in the phone, try and perform a software repair using Xperia Companion.
This will rule out that this is caused by the software in your phone and the latest available software will be reinstalled.
Do note that all data that you have stored on the internal storage in the phone will be deleted in this process, so it's advised to backup using Xperia Companion before you start with the repair process.
Let me know how it went!
Hi again!
In this case your phone will need to be examined by a trained technician at an authorized service centre. Your Local support team will gladly assist you with this and answer any questions that you have may have regarding local service procedures, warranty and so forth.
Keep me posted!
Hey everyone,
I get my phone checked at Sony service center. Motherboard of my phone has got damaged. It cost me 9600 INR, just after finish of warranty of 1 year
you may checkout your phone at service center, it charges 115 INR for inspection..
Hi again!
Sorry to hear that your warranty was expired.
Thanks for getting back to me and for telling me what the solution was!
