I bought it recently. Is there is another way to turn ON the c3 dual?. Now, the way I do it is by pressing the On and OFF switch on the right side of the unit. I have the unit in a case specifically designed for the C3 dual and it's difficult to press the switch. It's annoying!!
No,unfortunately you cannot turn it on without the button.
Thank you, well, I guess I need to get used to the fact...
If you are having a hard time pressing the power button or any other key then it might not have been designed properly for the Xperia C3, if its made of silicon you might be able to cut it
