Xperia C (2305) notification LED does not flash when receiving SMS or emails during stand by mode. Also If I missed any call it does remind me either. Every time I need to press power button what is very annoying.
Solved! Go to Solution.
Do you have STAMINA mode enabled in your phone? Check under settings > power management.
The LED notification will not work in stamina mode.
Hello Alexander..
But if i want to enable it in STAMINA mode how can i do it? Is there is any app for this or in built app to enable LED noticfication?
Kuindly please do reply...
I think you need an app from google play,which can be modified for any notification.
Hello Alexander,
Thanks for reply. If possible could please also suggest the suitable applicataion for same.
Thanks.
I am alexdon,Alexander replied in the upper post.Anyway,check this:
my phone xperia c doesnt notify me when i recieve whatsaap message....it notifies me on mails missed calls messages but not whatsapp ...what can i do ?
Are you using stamina mode?Sometimes it interferes with phone functions.
check the whatsapp settings..may be ur using purple or blue to light up or its in off....
