Camcorder not being seen by computer with iLink/Firewire cable
snapper27
Trying to get my DCR-TRV20E to work with new Dell Studio XPS desktop. Win7/64bit/ 16Gbmem. new PC!
Connect via firewire/iLink cable to USB,
Device not recognised. :cry:
According to compatability chart this should be OK.
Help anybody?
6 REPLIES 6
Do you really mean iLink to USB?
Have you tried an iLink to iLink cable?
:thinking:
snapper27
iLink is the same as FireWire.
I have a mini 4pin version that according to Sony is correct.
I was hoping to connect to the PC with this cable, (which is USB at the other end.) as there is no miniFW connection on the computer.
I was going to attempt to download a pile of family Video8 stuff onto my PC, but cant do that...
So the next option was link a V8Camcorder to my DV one, (that does a good A-D conversion,) then dump the resulting tape to the PC so I can edit it a bit before burning to DVD and handing original tapes back to daughter with the resultant DVD.
Messy I know.
I am aware that iLink is the same as firewire.  I was asking if your cable was iLink at both ends.
Your camcorder is only supported by Windows 7 through iLink  - you need an iLink unput to the computer.  It will not work through USB.
:slight_frown:
snapper27
So much for the guy in the shop who sold me iLink to USB! :angry:
I have ordered a iLink to 'Normal' FW from eBay.
I was rummaging round my 'Comes In Handy' box and found a 3 port FW card.
lets see where that gets me.
Do you know if it also Xfers sound at the same time?
It should transfer the whole file - sound and video.
Hope you get it working!!
:neutral:
snapper27
When I get the new cable I will know more. :smileygrin:
I will close this thread, Thanks for that. :slight_smile:
