CODE C:32:60 keeps flashing on screen of handycam HDR-TG1E
lynn2008
When I turn my camera on it goes to charge setting and message on screen keeps askign me to turn power on again . The  this message C:32:60 keeps flashign and my focus is not working at all .
Help anyone !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thalamus.
Champion
Hi lynn2008,
try this..
Disconnect the AC power and remove the battery for a few minutes then reconnect the battery and start your handycam again.
If this does not clear the problem then try resetting the Handycam, to do this place a pointed object into the reset hole on the left hand side of your handycam.
This should reset all setting back to default including the clock..
If the C:32:60 error code remains then you'll need to to contact Sony support as your handycam will probably need a repair..:smileysad:
Thalamus.
Champion
Hi lynn2008,
try this..
lynn2008
Thalamus
I did try all of the above as it instructed in the manual , it is now displying E 61:10 as well as C32:60
i will have to send to Sony for repair but could do with a quote first
Thanks for your help
Lynn
