I totally understand that over the last 40 years, advances in the understanding of the structure of matter and the interaction between thin slices of silica when sandwiched have led to a technological revolution: PC, cell, www...the list goes on.
The trouble with Sony is:-
If you SONY can answer these questions, I would very much appreciate it.
Message was edited by: -Finn-
Hi BillyJoelGoatGruff Thank you for your post, I have had to slightly edited the post to omit the four letter word. In addition, please be advised that Sony do not usually reply on the forum as it's a user 'support' forum where advice and experience is shared by Sony users. Kind Regards Finn (Forum moderator)
Solved! Go to Solution.
Hi BillyJoelGoadGruff.
This is a user forum for help from fellow users.
There is no currently produced equipment for DV editing. You have to use the equipment of that time - which means eBay.
You can buy second-hand recorder/players but they are rare and expensive: -
Probably cheaper to get an old Mini-DV camcorder: -
Alternatively, depending on how many tapes you have, you can get the contents professionally transferred to DVD for about £20 per tape.
