Is there a diffrence between the camcorder hdrj200 and the j200eb
Solved! Go to Solution.
Hello mrbigdave - Welcome to the Sony Forums
The letters after a camera model number usually designate the territory that it has been released into. Any model with an 'E' will be aimed at the European market and so the only potential difference
would be that it is compatible with the European video system (i.e. PAL) instead of another format such as NTSC.
If you would like more information, the support page for this camera is here:
http://www.sony.co.uk/support/en/product/hdr-pj200e
Thanks,
Simon
Thanks,
Simon
