do i need a i cable to connect my handycam dcr hc 35 to my desktop using window7
walshy123456789
do ineed a icable to connect handycam dcr-hc 35 to my desktop using windows 7
StartTheCar
Yep, you will need either an i-link, firewire or ieee1394 (they are all the same) in order to connect the Handycam to your PC.
walshy123456789
thanks, got  round it  gone through dvd recorder to burn some old tapes of the kids.
bit anouyed that sony have not made handycam compatible with winows 7 unless you
have a i cable input on your pc, which most dont  ,maybe thay want everyone to rush out and buy
new camcorders !
