Doesn't focus really close?
Neal81
What do I need to change so my Sony AX53 will focus quickly & sharp when I get really close to a flower?
Any help appreciated.
Neal
Hi Neal
According to the FDR-AX53 Specifications:
MINIMUM FOCUS DISTANCE
approx.1cm(Wide), approx.80cm(Tele), approx.13/32inch(Wide), approx.31 1/2inch(Tele)
So I guess the answer is to zoom out as far as possible and you should be able to get as close as 1cm.
Neal81
Hi Blencogo,
Thanks for the reply.
I already did that would manually focus be of any use at 1cm?
It also takes quite a few seconds for it focus when panning round generally, Are there any setting such Iris or Exposure that will help with this?
Neal
