Could anybody help me? I am looking for Driver for handycam DCR-TRV140E PAL Windows 7.
Solved! Go to Solution.
Hello famfil - Welcome to the Sony Forums
This camcorder is an iLink compatible model - this output is also known as Firewire. As such, this means that there is not a specific driver for your Windows 7 PC/Laptop. The only requirement is that you computer has a Firewire/iLink socket, and you will be able to connect your camcorder to that with the correct cable.
There is an online guide about transferring video to your computer, and it is here:
http://www.sony.co.uk/support/en/topics/videotransfer
Thanks,
Simon
Thanks,
Simon
