I have this handycam and have installed the software, however, when I plug it into my computer via the usb cable, my computer does not recognise it stating no connection has been made. Please help me as I have videos going back years which I now want to get onto my computer. Many thanks in advance
Hello 1slowLearner - Welcome to the Sony Forums
There may be a compatibility issue here. Could you let me know some more information about your system i.e. operating system, laptop/desktop and if your computer has a FireWire socket (this may be labelled as iLink). If in doubt, let me know the model number of your system if it is a regular retail model and I can check out the specification for you to see exactly what is available.
Thanks,
Simon
Simon, thanks you and thanks a million for your offer of help.
I'm using a toshiba equium A110-233 laptop which runs MS windows XP 2002. Thats about it as you lost me on the firewire socket/iLink.
I loaded the software CD, updated my adobe reader and flashplayer and am now at a loss.
I hope I've included enough info for you and thank you once again, you might just stop me from going grey.
Catherine
Hello again
Thanks for the information. I found the specification page for your laptop here:
In the 'interfaces' box, it states that there is 1 x iLink which is the FireWire input. If you are having difficulty getting the USB cable to function correctly between camera and laptop, I would recommend using the FireWire instead as it is a common format and the necessary cables are only a few pounds to purchase.
http://www.amazon.co.uk/High-Grade-Firewire-DCR-HC14E-Camcorder/dp/B004OUJKC6
This is one example, you may be able to find one for less than £5.99 by shopping around.
Once you have this lead, you need to use movie editing software to capture the video directly from the camera. For Windows XP, there is a specific version of Windows Movie Maker that will do the job. Provided that you have updated your version of Windows with Service Pack 2 (one of the automatic updates) this software should already be installed. Other than this, you could always download VirtualDub which I have heard is pretty useful.
This should be better than using USB with far better picture quality as well.
Thanks,
Simon
I will do as you state and let you know.
thank you so much for helping and giving your time.
Have a great evening and I will update once I have all in order.
Once again, thank you
Thanks let me know what happens
Simon
