handycam dcr-sr37 battery problem
kevin023
hello
i have a handycam sony dcr-sr37 which i have received as a present.i have a problem with it at the beggining it used to work well i attached the battery and the ac power adapter and charged it and worked with it perfectly.now i have a problem i attached the battery again and when i open it to use it the camera does not work it does'nt turn on when it is supposed to turn on automatically when you open the side for viewing  then when i attach the ac power adaptor again it starts to work perfectly.i bought a new battery charged it with the charger (because when i attach the power adapter to the chg red light starts flickering but does not charge the battery)what can be the problem?can it be an internal problem?since that the camera only works with the ac adaptor attached to it?and when there is only a charged battery attached it does'nt work
0 REPLIES 0
