Handycam HDR-UX3E and windows 7
georgeraggett
I have a HDR - UX3E and PMB software on a laptop running Windows Vista. A new latop has windows 7 can I dowload a new version of PMB that is compatable with Windows 7 and can I get the handy cam upgraded to get full functionality?
Watashiwateshdes
The good news is that you wont have to do anything other than visit the link below.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&f=PMB_V5502&m=HDR-UX3E
This will give you the latest version of PMB and support on Windows 7 (various versions are supported). You will need the original version installed (does not need to run).
If you get a message to state it cannot be installed, run the link below instead.
http://support.sony-europe.com/dime/downloads/downloads.aspx?&f=download_manager&site=odw_en_GB
Hope that helps.
georgeraggett
Thank you for that info.  Yes that has sorted it!
