handycam
jeanibeani
handycam
where can i find drivers for dcr- pc106e please
4 REPLIES 4
Hi jeanibeani,
All the available drivers are on the support website for your model here: -
http://www.sony.co.uk/support/en/product/DCR-PC106E/updates
:wink:
jeanibeani
thankyou for your help I checked the support website but I don't think its compatible with windows 7  I also tried Microsoft windows movie maker and that didn't recognise my handycam :thinking:
USB is not supported with Windows 7.
Have you tried using an iLink Cable (Firewire, DV) to connect to your PC and then use Windows Movie Maker?
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=iLink+cable&x=0&y=0
The iLink socket is in the Handycam Station - next (left)  to the Power In socket.  I believe it is only an output from the camera to the PC - you cannot transfer video from PC to the camcorder.
:thinking:
jeanibeani
Hi Blencogo,  thankyou for your help I will go for ilink cable tomorrow and try that, will be so happy if it works will let you know .
