HD recording only lasts 29 secs
cottoneyejoe50
I have just got a Handycam HDR-CX115E to record a wedding in May, everything seems to work OK except it won't record longer than 29 seconds in HD then data error pops up and it reboots the camera.
It's fine on STD quality the card is an 8gb memory stick pro duo Mk2 and has been formatted several times always with the same result.
Ace.
Johir-Ali
Hi, by now I'm sure you have sorted but just incase, in my case it was the cheap SD-card that did the same as yours & I went and got a kingstan and it works fine.
jo
