HDR-CX450 - is there a way to send clean HDMI for live streaming?
Is there a way to send clean HDMI signal, free of screen indicators, for live-streaming?  I plan to live stream with a few HDR-CX450 cameras using an Atem Mini Pro to send to YouTube, but I can't find in the manual or menus how to toggle the indicators off  (presently showing 'Menu', 'W', 'T', record red dot and the microphone indicator).
Peter_S.
Genius
You have to disable CTRL for HDMI in the menu:
If you do not want to display icons on the screen of the TV connected via HDMI, select - [Setup] - [ Connection], then set [CTRL FOR HDMI] to [Off].
Peter
Peter_S.
Genius
Peter
That's perfect Peter - exactly what I needed.  Many thanks
