HDR-GW66VE conversion lens + saving the lens
thmerlv
Have just bought the HDR GW66VE and want to preserve the lens as the camera will be used in the kayak. Is there no protection filter or a polarid filter to be mounted on existing lens.
Or tips on making a filte yourself?
It is mentioned in the manual that there is conversion lens but I can not find anything on your website
profile.country.de_DE.title
cmosse
for the HDR-GW55/66/77/88 the wide angle attachment VCL-HGE08G is available (it seems currently only in Asia)
http://www.sony.jp/handycam/products/VCL-HGE08G/feature_1.html#L1_10
http://www.sony-asia.com/corporate/resources/en_AP/pdf/AP%2824April13%29-EnjoyHassle-freeShootingand...
The camcorder itself does not feature a standard filter thread so you can not mount a protection filter to it. The camcorder however is quite rugged and usually does not need a special protection filter.
