The message you are trying to access is permanently deleted.
Is it possible to use my HDR PJ620 as a web cam?
I can't seem to find out how to do it.
Hi @Steve_B,
the camcorder can't be used as a webcam without additional hardware.
If you get a HDMI-capture card, you could use the HDMI output as a video source, which you can use for your computer.
But with just the camcorder that is not possible.
Why do you think that should be possible?
- Nic
