help drives for windows 7 64 bits camcorder DCR-TRV361
profile.country.es_ES.title
luisriveralozano
I have a video recorder model cdr-trv361, I need the drives USB STREAMING FOR WINDOWS 7 64 BIT. Please help me. Thank you
Unfortunately USB streaming is not supported in Vista or Windows 7.  There is only a USB driver for XP.
The only supported connection in Windows 7 64-bit is iLink (firewire) and that will only work for data transfer of files from camcorder to PC.
:thinking:
:thinking:
