Help to open photos .srf format loaded from DCR-SR58E not opening with windows 7
rorymer
Help required to open photos in .srf format loaded from DCR-SR58E not opening with windows 7
blaireau_photo
Hello rorymer,
Irfanview is a free image viewer that is compatible with Windows 7 and all the information is available at http://www.irfanview.com/. It lists .srf files as a compatible format as long as you download version 4.30 of the software or later. A full list of extra plug-ins for various file formats is located here.
Thanks - and good luck :slight_smile:
Simon
blaireau_photo
Hello rorymer,
Simon
rorymer
Many Thanks for your help
blaireau_photo
You're welcome - good luck :slight_smile:
