ILME-FX3 XAVC-HS 25p missing in PAL
I wanted to shoot on my FX3 in HS codec but since I am in Europe, the 25p PAL version is missing. Is there any way of fixing it or is Sony working on the 25p PAL version in XAVC-HS?
Tags (4)
Marino.Manolo
Genius
No 25p even in NTSC (in NTSC maybe XAVC HS 4K 24p):
https://helpguide.sony.net/ilc/2210/v1/en/contents/TP0002911203.html
danardeng
An update is out https://www.sony.com/electronics/support/camcorders-and-video-cameras-interchangeable-lens-camcorder...
check if there is any news about XAVCHS compression
