Manaul and Driver urgently needed
Ellie12
Hello All,
I need the manual and driver of sony camcoder: dcr-trv245e ASAP please.
Thx
Mick2011
Do you mean TRV245e? The TRV45e is Video 8 (analogue) which won't connect to PC without a video capture card.
The TRV245e really needs firewire to connect properly. I don't think the cameras USB port is 2.0, so it will be very slow even if you do get it to connect. A firewire card fitted to the PC would be the way to go.
I know you can get firewire to eSATA adaptors and converters, which might possibly work, but I can't guarantee it and they're often more expensive than the FW cards.
Mick
14 REPLIES 14
Thalamus.
Champion
Hi Ellie12,
welcome to Questions & Answers..:smileyhappy:
Is this what you are looking for - Instruction/Operation Manual
Ellie12
Hi Thalamus,
Thanks for the manual.
More importantly I need to install the software for this camera.
Otherwise it will not be recognised on my PC.
Thanks in advance for your assistance.
Thalamus.
Champion
what operating system is installed on your PC.?
Ellie12
Does anyon has the software needed to downlaod video from camcoder dcr-trv245e to PC please?
Ellie12
OS is Windows 7 Home Premium.
The Manual refers to a CD ( with needed software ( S/W)) which I can't find.
Anyway of downloading S/W from internet please?
Thalamus.
Champion
seems the original driver & software is not Vista or windows 7 compatible..
Does your PC have a firewire (iLink) port.?
Ellie12
No. It doesn't have a firewire port.
Ellie12
Help Everyone.
How do I transfer videos from Sony DCR-TRV45E Camcorder to PC?
My PC doesn't have a firewire port.
It has eSATA, HDMI and USB ports.
The Camcorder is not recognised when connected via USB port...
I haven't seen any adaptors or similar so far.
Your suggestions PLEASE!!!!
Thanks!
Mick2011
Mick
