MEMORY PRO SIZE
h10d1d46s6b85e22
MEMORY PRO SIZE
Hi my name is Mike can anyone tell me the largest size memory stick pro i can put in my HDR-SR10E CAMCORDER, i have a 8gig in now but would to increase size if possible many thanks
Watashiwateshdes
Hi Mike and welcome to the community.
You have a varied selection to chose from but the list on the link below confirms max of 32gb
http://sony.co.uk/support/en/product/HDR-SR10E/compatibility
Please note that there are limitations such as using high speed storage may not give you any advantage etc but either way, you can make a choice since memory these days is getting cheaper and cheaper.
Hope that helps.
Watashiwateshdes
Hope that helps.
