microphone FX Sony Handycam AX53 4K
Condle4l
Hello Everyone,
I want to record some evaluation comments and need to buy/learn about a mic I can purchase for the interviewee to heard more professionally, not just using the internal mic which picks up all sound.  Help required!
Thank you.
IamNic
Hello @Condle4l,
I can highly recommend the "RODE RodeLink Filmmaker Kit" for interviews.
- Nic
Condle4l
Thank you, and just to confirm, would you recommend it for this exact model?
Have you used it with this exact model - FX Sony Handycam AX53 4K.
Forgive me for being so specific - it's because I'm a novice.
Thank you so much for taking the time to reply.
IamNic
Hello @Condle4l,
I have not used the microphone with the AX53, only with the AX43, AX100 and AX700, but I am 100% certain it works with the AX53 just as well.
- Nic
