I have a Sony HDR- TG7 Handycam with some movies in the Internal Memory .
I wish to ' Dub ' these onto a Pro Duo 8GB ( empty ) which I have inserted .
Following the Handbook instructions ..... MENU > EDIT ( No. 7 ) > MOVIE DUB
On screen ' Warning ' ..... " HD Movie recording disabled " ..... ???
can anyone tell me in simple steps how to do the required dubbing !
Solved! Go to Solution.
I am going to answer my own question here as I have experimented and found the answer.
The New ( empty ) Pro Duo card had not been ' formatted ' to the TG7 Handycam ... so I changed the Media setting from Internal to Media card , inserted the Pro Duo card and ' shot' a few seconds of video , viewed and then deleted . This action must have ' formatted ' the card .
When I again tried to Dub the internal videos to the new Pro Duo card ..... it worked !!! .... Job done.
I can now play the old videos from the TG7 on my new HDR-PJ420VE Handycam which takes Pro Duo and SD cards . Is there a market for the TG7 ???
Hi bbz968,
I'm glad you found a solution and thank you for sharing it with the community.
