Need a vista driver for sony dcr-pc330e
profile.country.no_NO.title
tk901399
I have a older camcorder sony dcr-pc330e and i want to transfer the videos to my PC so i can edit them in Pinnacle. I have vista on my PC and i cannot find drivers for later OS then XP.
Anyone have a solution for this?
Looking at the support page for your camera, it seems that using an iLink cable should be generically supported by Vista and Windows 7.  It should be possible to copy the files using something like Windows Movie Maker.
http://support.sony-europe.com/dime/compatibility/cam/win7/cam_win7.aspx?site=odw_en_GB&m=DCR-PC330E
MemoryStick should also work.  Pinnacle 12 imports from iLink (firewire) but I don't know about other versions.
:thinking:
:thinking:
