PJ410 and youtube?
VFtech
PJ410 and youtube?
Hello
I am unable to find out how to livestream through youtube with my HDR-PJ410. Is this because it is not possible?
Can I only use Ustream with this camera for livestreaming?
Any suggestion are welcome 🙂
thx
IamNic
Hi there ,
I successfully used the AverMedia Game Capture Portable together with the free software "OBS Studio" to stream to YouTube using my cameras HDMI output.
You simply connect your camera to the HDMI-In port of the AverMedia Game Capture Portable and select it as input source inside OBS.
Also you need to install the AverMedia Stream Engine, which you get on the manufacturers website, to enable the video stream to be used by OBS.
- Nic
