Recording and broadcasting 4k through HDMI? AX100, FDR-AX700, etc.
Hi. I'm researching the limitations of the AX100 and the FDR-AX700.
I need to be able to broadcast a 4K transmission at 40 MBPs. Can either of those cameras do it? I heard they only broadcast 4K through wireless and the HDMI output gets disabled because the processor can't handle it.
If that is the case, what camera would you recommend?
IamNic
Hello @ZwoopMugen,
definetly don't go for the FDR AX100, since it can only output a HDMI signal when recording 1080p.
The FDR AX700 can output 4K via HDMI even if you're recording, but you can't use the cameras LC-Display (flip out screen) at the same time.
For broadcasting I would use a PC with OBS and as video grabber I would use a Elgato Camlink 4K.
- Nic
