Sony CX 350V - how do i record onto a SD card
supatel10
Basic question but I cant figure it out! I have inserted a 32GB SD card. Every time I open the CX 350V it says the internal memory is full. Fair enough but how do I switch recording directly onto the SD card?
Watashiwateshdes
Hi
As default, the Handycam is set to record on the internal memory, to change it, you will need to tell it that you want to record to the SD card instead. What you will need to do is follow the steps below, just ensure the card is inseted prior to continuing.
- Press Menu
- Look for Manage Media
- Within that menu, select Media Settings
- Within that menu, select Movie or Photo Media Set and then choose what you wish to record to.
After that, you should be able to continue shooting onto your SD card.
Hope that helps.
Mitesh
