Pease could someone tell me the best way to get my video from my DCR-TRV20E to my iMac? What cables do I need?
Solved! Go to Solution.
Hi scoxhead, welcome to the Sony Forums
You need a 4-pin to 6-pin Firewire cable connected to the DV OUT port on your camera. The plugs look like this: http://www.yycomputer.net/products/cable/firewire4-6.jpg
Just plug it in, launch iMovie on the Mac, power the camera up and click the camera icon (usually bottom left of the iMovie window) to see your movie clips.
Let me know if you need any more help.
Mick
Mick
Mike, Thanks for the response. I do have a cable that looks exactly like that which I used with my previous windows computer but my iMac does not appear to have a slot that fits this cable.
Steve
Sorry, I missed that it was an iMac you were asking about. Recent iMacs only have the squarer 9-pin FW800 port. The cable you need is this one:
http://www.amazon.com/9PIN-4PIN-Firewire-800-Cable/dp/B000VEOIDK
Mick
