Sony FDR AX700 Viewfinder Not Working
Hey guys purchased a Sony FDR AX700 and the viewfinder is not working. I can pull the viewfinder out and it powers the camcorder up but there is no image at all inside the viewfinder. And I have the LCD screen closed. Any suggestions?
Elodin
Moderator
Hi @Cypher6269, If you extend the viewfinder while the LCD monitor is open, the display switches from the LCD monitor to the viewfinder when you position your eye near the viewfinder. It is explained here. I hope this helps
