Hi, I have purchased a second hand Handycam DCR-DVD308e. It only comes with a disc for software to be installed on old versions of windows. Does anyone know if I can get a disc that will install the software on Windows 10?
Hi Stefnjez and welcome.
You can download the Windows software from the Sony Support page for your camcorder. You can also download the manual which shows you how to play back the DVD on other devices (provided they accept 8cm DVDs).
https://www.sony.co.uk/electronics/support/dvd-camcorders-dcr-dvd-series/dcr-dvd308e
