Sony handycam
profile.country.en_BG.title
sinemorec
Sony handycam
Dear all, could you please help me with transfering my videofiles to the PC? I would like to do that without finalizing the DVD disc. Do you thing that will be possible?
Mick2011
Hi sinemorec, welcome to the Sony Forums :slight_smile:
Most people use Sony's Picture Motion Browser (PMB) which is available from the Support section of this website, if you find you don't already have it installed on your PC.
This video is a step-by-step guide to downloading to your PC using PMB: http://www.sony.co.uk/support/en/topics/videos/PMB_import
Finalizing is necessary unless you want to bypass the PC and play back the footage directly on an other player.
If you find you have problems, get back to us and someone wiill help you out :slight_smile:
Mick
Mick2011
Mick
sinemorec
Thank you very much for your answer.
