Sony pro camcorder HXR-NX80 4K NXCAM has no 1080p 30fps HDMI output ?!?
yapandy
Hi everyone.
Just recently purchased the camera for more professional work just to find out that the camera does not output 1080p 30fps through HDMI. Is this really true? Seriously?!
Apparently it does 4k 30fps HDMI output, but i need it to be 1080p. It does 24fps and 60fps, so i just can’t understand what is the problem with 30fps with sony.
I did read the manual quickly through to find out this, but apparently i misread the pretty messy chart by sony.
Does anyone know any sony camera that does this?
I am sure it would be such an easy change to make by Sony through firmware update, so please Sony if you are listening make it happen! Outrageous.
Tags (3)
IamNic
Hello @yapandy,
for support on professional Sony cameras you can get direct support via this site: https://pro.sony/en_GB/support-content
- Nic
Sean_Mc
Moderator
Hi there,
As this is the Sony Electronics forum I would recommend you get in touch with Sony Pro for further advice here.
Best wishes,
Sean Mc
