Can Anyone Help,
where can i get a cd (usb driver) for my sony trv340 Handycam,!!
Regards
Tanya
Hi Tanya.
You can download the USB driver for Windows XP from here: -
http://www.sony.co.uk/support/en/product/DCR-TRV340E/updates
However, there is NO USB driver that is compatible with Vista or Windows 7. If you are using Vista or Windows 7, you need to use a DV Cable (also known as iLink or Firewire) which is supported by Vista and Win 7 without drivers.
You obviously need to have an iLink port on your PC or have an ExpressCard slot to be able to install an iLink port. You can then import your videos into Windows Movie Maker.
