Windows 10 driver for Sony DCR-TRV22E Handycam
Countryrambler
When using the correct Sony lead into my PC's USB socket, Windows 10 Device Manager can see there is an unknown device. When I load the original Image Mixer CD, containing the Driver, it says:- Error extracting support files, access denied. Does anyone know if a Windows 10 Driver is available? Thanks
11 REPLIES 11
Countryrambler
Long story, but I first need to fit a new optical drive on my PC to even read the mini disc with the capture hardware. I will then make the connections as you kindly stated. Thanks very much for you help.
Joe_Dohn
Specialist
Thanks a lot for all the info @darkframe I wasn't aware that Windows 8.1 actually officially supported Firewire among other things.
@Countryrambler do let us know if you encounter an issue once you get the drive installed, hopefully all will work smoothly though!
- JD
