Windows 10 update causing problems with trimming function on playmemories home
HemelHev
I have been using Playmemories Home to edit recent video footage without any problem - until my computer asked me if I wanted to install updates for Windows 10.
Since then although the software allows me to select the footage I want to edit, allows me to go to the Trim Video option and allows me to select my required 'in' and 'out' points on the footage, when I click on the 'Save edited video' button the processing bar comes up briefly and then an error message 'Unexplained error found' pops up and the save is aborted.
Clearly it's a glitch created by the wretched Windows 10 update, but I can't solve it.
I've uninstalled and re-installed PM Home in the latest v.6 64 bit version but this hasn't helped.
Any ideas?
Pascale_F
Moderator
Hi HemelHev,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi HemelHev
Have you tried running the application as administrator?
Win_88
