Hello Mikeb7 - welcome to the Sony Forums
Do you have the original part number from the previous remote commander (it should be printed on a sticker/panel on the commander itself). The reason that I ask is that there are various spares available which should help pinpont exactly which remote you need.
There is a generic remote listed here ........
........ but it would be wise to check to see if there is a part number first on the remote so that you can shop around.
Thanks,
Simon
Thanks,
Simon
