accsess on start up
tepleav
accsess on start up
i have a dsc-w50 when i turn the camera on a accsess sign comes on the screen and i have to wait around 20 seconds before i can use the camera does anyone know if it can be turned off as its a pain waitin many thanks
4 REPLIES 4
blaireau_photo
Hello,
This screen is appearing at start up because the camera is initialising/starting up with the memory card that has been inserted within - it isn't usually a feature that can be switched on/off.
Simon
tepleav
thanks just tried my camera without card and your right just got to find how to switch it off now many thanks for your help
terry
blaireau_photo
Hello,
You're very welcome!.
Another possibility could be that the card you are currently using might benefit from being formatted (once you have backed up any existing photos/other files on there). This may improve access speed if the card hasn't been formatted in a while.
Thanks,
Simon
tepleav
found it you have to go into menu - setup - then go down menu and click initialize and that sorts it again many thanks
Terry
