Advanced Manual
Cyrano7
Advanced Manual
I have recently bought a Sony
DSC HX 200v
I need a hard copy of the Advanced Manual. Where can I get one ?
Thalamus.
Champion
Hi Cyrano7,
Welcome to Questions & Answers..:smileyhappy:
Unfortunately, as with most manufactures, Sony do not supply hard copy user manuals with their products any more..
Up until recently Sony used to have the the User guide (advanced manual) available to download in .pdf form but this has now changed to a web based HTML manual, which unfortunately is not printer friendly..
However if you have adobe Acrobat on your pc or know someone who does then it is possible to create a .pdf file copy of the HTML manual which will allow you to easily print..:smileywink:
I would have happily done this for you but alas I do not have adobe Acrobat on my current pc..:smileysad:
blaireau_photo
Hello Cyrano7 - Welcome to the Sony Forums :slight_smile:
If you are referring to the manual that is available electronically here:
http://pdf.crse.com/manuals/4445796511.pdf
This may be available by contacting Sony Customer Services. The details are on the following page:
http://www.sony.co.uk/support/en/contacts/dime
Thanks,
Simon
Thalamus.
Champion
Hi Cyrano7,
profile.country.de_DE.title
cmosse
you can download the PDF version of the advanced manual (cybershot user guide) from here:
It is in PDF format so you can print it very comfortable (280pages single):
https://www.dropbox.com/s/zon61wzc2i789nf/DSC-HX200_HX200V_Cyber-shot%20User%20Guide_En.pdf
