Anyone know how to reset Playmemories database of seen imports?
Alan1947
Reason I ask is that Playmemories regards all new media file as "seen" and refuses to upload them. 😠
Can I change 'upload only new' to 'upload everything'?
Where is the database - can I delete it so PM starts afresh?
Any other tricks?
I have 2 Sony cameras - both are suffering - my only option is to connect using USB which rather defeats (and makes obsolete) the whole Wifi upload feature, how can they do this???
Joe_Dohn
Specialist
Not sure about where the database is, but if you're using Windows, you can use a "deep/full uninstaller" like Revo Uninstaller or something similar which clears registry and saved/related files. Can't give more info if you're on a Mac cuz I don't own one myself at the moment sadly.
