ARW van RX10IV
profile.country.BE.title
1pippenel
ARW van RX10IV
Er is op het ogenblik geen enkel programma dat de ARW van een RX10IV kan kan omzetten naar bvb tiff, ook de Sony raw image data converter v.5 niet.
Wanneer kunnen wij een oplossing verwachten ?
4 REPLIES 4
jumpsuit
Hi @1pippenel and welcome to the UK Sony Community :slight_smile:
Please try and post in English here if you can.
Thanks :slight_smile:
1pippenel
There is currently no program that can convert the ARW from an RX10IV to, for example, tiff, also the Sony raw image data converter v.5.can it not
When can we expect a solution?
jumpsuit
Hi again :slight_smile:
Thanks for re-posting in English :beers:
Nice camera!!!
I don't have any info on a solution yet  however there may be a workaround for you
by switching the Raw files' profiles to RX10 III using ExifTool software.
They can then be converted, for example, in Capture One Pro.
I haven't tried this myself but here's a link to the software:
Click here
Please scan it etc. before using it.
Hope this helps :slight_smile:
Baz2126
Hi, try this: https://affinity.store/en-gb/
Brilliant! I have an RX104M and it works fine with Affinity.
Baz
