Does the Sony DSC-QX30 work with Play memories on Windows?
profile.country.IE.title
bh.10111444
I am looking for a camera that has high optical zoom that would connect to a laptop for daily use. Is this a good camera for this? And is there better options out there?
I am visually impaired and need a distance camera to see the board if I ever return to lectures because of Covid.
any help would be much appreciated.
profile.country.NL.title
Strampke
The PlayMemories mobile app is discontinued and replaced by the ImagingEdge Mobile app.
It is compatible with your DSC-QX30 as far as can seen on this webpage.
Information about DSC-QX30 and PlayMemoriesHome can be found on the Sony DSC-QX30 support page.
I suggest you to take up contact with a association for visualy impaired people in your country.
They are the ones that are experienced and can give you the best tips from daily practice.
