downloading photos
harwoodlad
downloading photos
When I click "send to computer" in the menu on
my DSC-HX60v I get the following message;
Information of the computer where the data is to be saved is not set to the device. Connect the computer to the device with a USB cable and set it.
Any ideas on how to set it please?
Regards,
harwoodlad
Peter_S.
Genius
You have to install PlayMemories Home first and then register the access point in the camera.
See also: https://helpguide.sony.net/gbmig/45299231/v1/en/contents/TP0000518267.html
Peter
harwoodlad
Many thanks Peter - I'll give it a go later today.
Phil
(harwoodlad)
cheddarman
Good luck with that, very few actually manage to get it working. You could also try Imaging Edge   if that doesn't work.
