DRIVER DOWNLOAD
jimkit
DRIVER DOWNLOAD
HI
HAVE LOST CD FOR MY CAMERA (DSC-S80) NEED TO KNOW WHERE TO GET DOWNLOAD SO CAN INSTALL ON NEW PC
blaireau_photo
Hello jimkit - welcome to the Sony Forums :slight_smile:
As it appears that the Sony Support page doesn't have the drivers listed, you may wish to consider purchasing a USB memory card reader (these can be found for less than £5 usually) and then using this to transfer images to your PC. Some PCs even come with a reader as standard so check your new computer first.
Some users prefer this to installing the software as it offers a simpler solution using Windows.
Thanks,
Simon
blaireau_photo
Thanks,
Simon
