DSC H200 mode dial issue
profile.country.US.title
jeffwecker
Having problem with the mode dial on my DSC H200 . When I put it on "Program auto" , then shut it off, and turn it on later to use it, it shows as being in intelligent auto. What is wrong and how can I fix it? Batteries are new alkaline
6 REPLIES 6
Pascale_F
Moderator
Hi Jeff,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Jeff,
Have you tried resetting the camera?
https://helpguide.sony.net/gbmig/44454171/v1/eng/contents/07/02/05/05.html
Win_88
jeffwecker
Link does not work , I get this :
Sorry for inconvenience caused. The requested URL could not be retrieved.
If you still see this page after retrying to retrieve the URL, Please consider the following.
  • The page has been moved to another address.
  • The page has been deleted.
IamNic
Hello @jeffwecker,
try again, there was a mistake in the URL which I corrected.
- Nic
jeffwecker
I tried resetting it,  still does same thing.
The_Black_Rose
Specialist
Hi Jeffwecker,
I know this sounds very basic, but have you tried to remove the battery for a minute to perform a power reset?
Cheers,
The_Black_Rose
