DSC H200 will not reset.
monsterbee
I had not used the camera for a while and when I did it came up on the language setting. It will allow me to select a language from the list but then the ok button will not work. I've tried a reset but it still switched on with the same message.
Sean_Mc
Moderator
Hi there,
There are three possible methods to do a reset.  You can see more details here.
Let me know how you get on?
Best wishes,
Sean Mc
monsterbee
Thank you. Holding the power button down for 30 seconds worked.
Many thanks again
Sent from Samsung tablet
