DSC HX200V
profile.country.el_GR.title
evastathakopoulou
DSC HX200V
i wanted to ask if the camera DSC HX200V has good picture quality and gereral if it takes "clean" photos. i don't care particularly in video production be clean photos and right focus. generally tell me your opinion about her..
blaireau_photo
Hello and Welcome to the Sony Forums :slight_smile:
In my honest opinion, the DSC-HX200V takes good photos and has a range of settings available (although if you prefer, you can simply leave it on 'automatic' and let the camera do the hard work for you). Although videos are not a particularly big concern, it does take HD quality video and this can be a useful feature to have for those unexpected moments.
The optical zoom lens is 30x which will give you a large zoom range before the picture begins to pixelate/distort and the Optical Steadyshot will also give 'clean' results if you are moving the camera at the same time as trying to take a photo.
I could give you other information about this model but I may begin to sound like an advertisement :smileyhappy:. I suggest that you also take a look at the following pages:
DSC-HX200V official specification - http://www.sony.co.uk/product/dsc-h-series/dsc-hx200v
Sample images: http://www.ephotozine.com/article/sony-cybershot-dsc-hx200v-sample-photos-19288
If you have any specific questions about your own individual needs, please ask.
Thanks,
Simon
evastathakopoulou
it takes good pictures in low light and night? have you that camera to know? because i told you i interested to the clean image in the camera..
Mick2011
A lot depends on your personal taste.
The HX200V does produce exceptionally clean-looking images, with very little visible grain even at quite high ISO; however some users dislike the 'smoothing' effect of the noise reduction that the camera applies, when viewed at 100% magnification.
Assuming you don't normally view your photos at 100% magnification (not something you would normally see in print, for example) then you should find the output to be very clean in normal use.
Mick
