DSC-HX300 driver for Windows XP
An_Dimo
I recently bought a DSC-HX300 camera. On my PC I still use the Windows XP and the driver for downloading pictures from the camera to the PC requires Vista or later version of Windows. Is there any solution for XP fans? :slight_smile:
Thanks!
Trail_Finder
Old Post have you sorted this out by now!  I hope so
XP Don't matter and plug camera into USB slot then look at MY Computer and see the camera/memory card as a drive.
open and drop & drag file to folder.
Also could take memory card out and pop into a card reader then plug the reader into USB.
Also you do know XP not supported by MS now.
